burnham gas fired boiler
nanna
Member Posts: 2
in Gas Heating
My burnham gas fired boiler has an automatic feed. I am having a problem with the water feed filling up even though the vial is at the normal water level. It will click on and feed water until the vial is full and keeps going. I shut the unit off and drain the water to the regular spot on the vial. It will work for awhile and then It will continually feed the water again. At one point I saw water on the floor.
LWCO
It's very likely that the low water cutoff is incorrectly telling the water feeder to add more water to the boiler. Do you have an internal probe low water cutoff, or an external float low water cutoff? How old is the boiler?0 -
Burnham gas fired boiler
The boiler is just 5 years old. How do I tell if it is n internal probe low water cutoff or external float? I can tell you that there is a small black box that has a green light and a red light on it.0 -
Steam boiler?
Hi, this sounds like a steam boiler since you mentioned the vial (gauge glass). My boiler is set up the same, so you have an internal LWCO.
If you post in the Steam section you will most likely get a lot of views and likely multiple responses as well. There are many of us who view multiple forums, but you will get the largest volume of assistance from that group as they are geared specifically towards 1 pipe and 2 pipe steam systems and associated boilers.
Note: Bustoff, please don't take my comment as a slam. as I see that you service steam systems. I am just offering a suggestion about a forum directly linked to steam.There was an error rendering this rich post.
- 116 Geothermal
- 15.8K Strictly Steam
