Slant/Fin Concept 21
DZ
Member Posts: 1
My boiler is on the fritz the red light for Flame is blinking the manual is saying Power connections polarity reversed. Boiler is 10 yrs old . We haven't done anything to it so I'm wondering how polarity would have changed or is there something different that would cause this??
Polarity
You may have a bad connection in the boiler circuit, particularly in the neutral.Bob Boan
Bad Ground..
Check for a bad ground..Many times a loose wire or missing Ground..Voltmeter and basic know how to use it is necessary,,0 -
Slant/Fin Concept 21 Boiler
My boiler, Slant/Fin Concept 21, stopped working. The indicator light is flashing, no ignition. I have natural gas. Help. I do not smell gas but as a precaution I turn off the boiler at the circuit breaker.0
