triangle tube with trimax
metny
Member Posts: 1
Please help, getting a hard lockout. Failed ignition after five attepts. Check gas supply, which i did and is clear and working fine. I think its a fluke. But how do i reset the hard lockout, is there a button somewhere? Please help.
Lock out
You should be able to power the boiler off than on to reset.
You can check the error log and see how many times it has happened.
A bad ignitor is one common cause.
Albert Einstein0 -
iGNITER
Have way too much experience with this0
