triangle tube with trimax
metny
metny Member Posts: 1
Please help, getting a hard lockout. Failed ignition after five attepts. Check gas supply, which i did and is clear and working fine. I think its a fluke. But how do i reset the hard lockout, is there a button somewhere? Please help.
  • Zman
    Zman Member Posts: 7,611
    Lock out
    You should be able to power the boiler off than on to reset.
    You can check the error log and see how many times it has  happened.
    A bad ignitor is one common cause.
    Carl
    Albert Einstein
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    iGNITER
    Have way too much experience with this
