Difference in aquastats
John Mills_5
Member Posts: 952
Anybody know the difference between L8148E1165 and 1299? Will the 1299 work in place of the 1165?
Thanks
Thanks
Correction
According to Bryant it is a 433-00-523
(ECR part #) which appears to cross to a L8148E1257. So the question would be, does anything cross to that, such as the -1299 I have in stock, or do I have to go back to Bryant/Carrier/ECR?0 -
Other than
some of the L8148E relays having a vent damper plug the 1299 should work if yours does not have the damper plug. The 1265 has the vent damper plug. Or you could use the Universal replacement L8148J-1009 which can be used on 24 volts or on millivolts. The "J" does not have a damper plug adaptation.0 -
Thanks Tim
The current one and the -1299 both have the damper plug and our boiler has a damper. Would we be best going with the -1265?0 -
Yes John
that is the best bet.0
- 50 Industry Classes
