new home owner from philadelphia
viali8
Member Posts: 28
hello all,
I just purchased my first home here in philadelpia. It is a great old house but also has steam heat. I could fire off a ton of questions but want to continue reading through the forum as I am sure I will find some more answers on here. I already found out that the new boiler installed by the previous owner was done incorrectly..,it was installed with some copper pipes :(
But I do have one question before I continue reading...can anyone recommend a reputable guy who knows about steam systems in the philadelphia area?
Jstar
Absolutely.
Thatcher heating and cooling.
http://ecuacool.net/
They recently changed their name to Thatcher heating and cooling so don't be confused by the different url. They are one of the best in the country and I believe will do your area.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Contractor
Look in find a contractor0 -
While you are waiting for the pro.........
Tell us about any problems the system may have. Is it 1-pipe or 2-pipe.
Is it uneven, or noisy, or are you just wanting to be proactive, and identify any potential issues before they become major?
If you are lucky enough to have Jstar look at your system, you will be in good hands.
Do a search for his name and see if you can judge him by his postings here.--NBC0 -
right in your neck of the woods...
It looks like Jim is only a few miles from you...what a problem to have: two wallies fairly nearby. I'm patiiently waiting to see if one will pay me a visit!Two-pipe Trane vaporvacuum system; 1466 edr
single pipe system
Thanks for the reply guys!
I have a single pipe system. A new utica PEG E series was installed in preparation for selling the house. I had nothing to do with the install. When I went to see the house there was a leak in the piping near to the boiler. Little did I know at the time that copper was not to be used for near boiler piping. My realtor recommended a heating guy and I had him come out to take a look at it. He did mention any thing about the copper piping! Therefore I am assuming he is not familiar with the steam heat system. As I have been reading more and more I think the install was not done correctly.
Here are some of my symptoms:
water hammer
water in some of the radiators
uneven heat
leak in the copper pipe
I was able to find an installation guide on utica's website. I compared the pics in the installation guide with my boiler and I do not think it was installed correctly. I have reached out to Jstar last night and he responded promptly. I am still waiting to hear back from him. I hope he can come down and take a look at my system.
Regards
Matt0 -
Post some pics of your boiler
You are in good hands with jstar0 -
Pics?
Could you post some pics getting as wide a shot as possible and from a few different angles. Plus, some close-ups of the controls and pressure gauges Quite a few things could cause the symptoms you describe, from too high a pressure to mis-pitched pipes and bad venting either on the mains or rads themselves. A few pics might help clarify. Also, when do you get the clanging...at the beginning of the cycle, middle or end?Two-pipe Trane vaporvacuum system; 1466 edr
one pipe steam system
Vaporvac,
I get the clanging in the beginning of the heat cycle. I will get some pics as soon as I can. My camera phone hasn't been working well recently. Fingers crossed.
Thanks
Matt0 -
here some pics
here are some pics of the boiler. Bad news is I don't think it is installed properly and it was done with copper...good news is that Jstar is coming over take a look at it next week.0 -
Where to start?
I see a bunch of issues right off. But if JStar is coming, he'll get you straightened out.All Steamed Up, Inc.
Consulting0 -
Just for fun
I started making a list. Keep in mind that while I'm pretty good with hot water, I have limited steam experience.
Clearly wrong:
Copper steam pipe.
Missing riser from second boiler tapping.
Insufficient "A" dimension.
No piping from PRV outlet.
Possibly wrong:
Improper Hartford loop (can't see thanks to camera angle.)
Undersized header piping.
Not sure what the skinny copper line leaving the header is (Pressuretrol?)
Whatever the issues, Joe will set you straight.0 -
draft hood
Besides the horrible steam piping, are there two draft hoods!?!?!Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Draft Hoods
Yes, there are two of them. So the vent damper (if that's what I'm seeing) isn't doing much good.Just another DIYer | King of Prussia, PA
Amazing
This might win the "piped wrong" award. Not only is the steam piping wrong but they somehow managed to mess up the flue as well. Can't blame that on someone that only knows hot water systems.
Obviously done by someone who had no business touching any heating system.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
piped incorrectly
Thanks for the feedback guys. I figured that this was not installed correctly. Ignorance is expensive...when I went to go see the house I knew zilch about steam heat. If I knew what I know now I would have had the seller give me a credit...anyway it needs be taken care of. JStar is coming out next week so I hope he can help me out.
That skinny copper pipe coming from the header is for the automatic water feeder. Should it be there?
Thanks
Matt0 -
Automatic water feeder
definitely not!0 -
bad piping
I have been using he boiler like this for a couple weeks. it still produces some heat. Jstar isn't coming until next Monday. Do you think I am doing serious damage to the boiler by using it when its piped the way it is. I have the temp. set at 55 during the day and 63 when I get home in the evening. Should I shut it off and spend time at a relatives house until Jstar comes over?
Thanks
Matt0 -
nothing will happen
that hasn't happened so far. Steam systems are rugged and the question is how much harm has been done in the years since that was installed. Anything from now till next week is inconsequential.
Let it do it's best to warm the place up.
3PSI gauge0 -
sounds good
The boiler was installed right before I moved into the house. Not more than 4 weeks ago. Actually the boiler wasn't even used as the previous owner moved to Oregon and had someone install a new boiler in preparation to sell the house.0 -
hope you
Hope u can go after the installer and make them pay for the repiping job.. that installer have no business of installing boilers.0 -
IOM
I've attached our IOM for the PEG-E steam boilers. Pages 10-11 show the near boiler piping diagrams.
It makes me cringe to think of what might be happening when that water feeder kicks in...0 -
thanks!
Thanks for the PDF file! I am no genius but my the way my boiler is piped is not even close to what it looks like in the diagram. Damn this pisses me off....the screwed up thing is that my realtor recommended a few guys to take a look at the boiler. I contacted one of them and obviously received bogus information. No I have to pay for it0 -
keep
Keep bugging the Realtor... give him or her guilt trip for having you go thru major expenses by having these kunkleheads check out ur system..0 -
Steam
Those pictures are so hard to look at. So many issues....
All realtors have a crew of goonies to do their assessment work done quick and cheap just to sell the house (in fact, we do this type of work for several realtors). But, I would be upset about this, too.
Steamhead always says that you can't fix stupid, but you can certainly fix stupid work. Not all is lost....as long as the boiler is the right size.0 -
steam
I will confirm what model the boiler is. I am pretty sure I can access some PDf files from the Utica website with some helpful information.
Thanks
Matt0 -
Update
Well, this mess was finally cleaned up today.
We replaced all of the piping. Corrected the bad venting connections. Added a massive amount of main vents. And installed a 2-stage GCV with Vaporstat to run on High/Low. After firing, the 60-70ft main was hot in under 5 minutes.0 -
Now that's some nice work
but we shouldn't be surprised, should we?
JStar, what turn-down are you using on that 2-stage valve?All Steamed Up, Inc.
Consulting0 -
Gas Valve
Low Fire is 60%. It is non-adjustable as far as the manufacturer says. Though, I'm sure there is a way to adjust it with a new spring under the Low Fire solenoid valve. However, 60% seems ideal for steam because Low Fire almost always matches the connected EDR load.0 -
nice install as always
one question about venting.Is it ok to wye the venting for both units or should they have seperate penetrations.I get a lot of conflicting answers.Thanks .0 -
Nice job!
Everything looks great, but I especially like the header. You are a genius when it comes to designing effective headers in cramped spaces.Just another DIYer | King of Prussia, PA
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
