new home owner from philadelphia
viali8
viali8 Member Posts: 28
hello all,
I just purchased my first home here in philadelpia.  It is a great old house but also has steam heat.  I could fire off a ton of questions but want to continue reading through the forum as I am sure I will find some more answers on here.  I already found out that the new boiler installed by the previous owner was done incorrectly..,it was installed with some copper pipes :(
But I do have one question before I continue reading...can anyone recommend a reputable guy who knows about steam systems in the philadelphia area?
  • ChrisJ
    ChrisJ Member Posts: 17,104
    Jstar
    Absolutely.
    Thatcher heating and cooling.
    http://ecuacool.net/
    They recently changed their name to Thatcher heating and cooling so don't be confused by the different url.  They are one of the best in the country and I believe will do your area.
  • Jim Pompetti
    Jim Pompetti Member Posts: 552
    Contractor
    Look in find a contractor
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    While you are waiting for the pro.........
    Tell us about any problems the system may have. Is it 1-pipe or 2-pipe.
    Is it uneven, or noisy, or are you just wanting to be proactive, and identify any potential issues before they become major?
    If you are lucky enough to have Jstar look at your system, you will be in good hands.
    Do a search for his name and see if you can judge him by his postings here.--NBC
  • vaporvac
    vaporvac Member Posts: 1,520
    right in your neck of the woods...
    It looks like Jim is only a few miles from you...what a problem to have: two wallies fairly nearby. I'm patiiently waiting to see if one will pay me a visit!
    Two-pipe Trane vaporvacuum system; 1466 edr
    Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF
  • viali8
    single pipe system
    Thanks for the reply guys!
    I have a single pipe system.  A new utica PEG E series was installed in preparation for selling the house.  I had nothing to do with the install.  When I went to see the house there was a leak in the piping near to the boiler.  Little did I know at the time that copper was not to be used for near boiler piping.  My realtor recommended a heating guy and I had him come out to take a look at it.  He did mention any thing about the copper piping!  Therefore I am assuming he is not familiar with the steam heat system.  As I have been reading more and more I think the install was not done correctly.
    Here are some of my symptoms:
    water hammer
    water in some of the radiators
    uneven heat
    leak in the copper pipe
    I was able to find an installation guide on utica's website.  I compared the pics in the installation guide with my boiler and I do not think it was installed correctly.  I have reached out to Jstar last night and he responded promptly.  I am still waiting to hear back from him.  I hope he can come down and take a look at my system.
    Regards
    Matt
  • ALIGA
    ALIGA Member Posts: 194
    Post some pics of your boiler
    You are in good hands with jstar
  • vaporvac
    Pics?
    Could you post some pics getting as wide a shot as possible and from a few different angles. Plus, some close-ups of the controls and pressure gauges Quite a few things could cause the symptoms you describe, from too high a pressure to mis-pitched pipes and bad venting either on the mains or rads themselves. A few pics might help clarify. Also, when do you get the clanging...at the beginning of the cycle, middle or end?
  • viali8
    one pipe steam system
    Vaporvac,
    I get the clanging in the beginning of the heat cycle. I will get some pics as soon as I can.  My camera phone hasn't been working well recently.  Fingers crossed.
    Matt
  • viali8
    here some pics
    here are some pics of the boiler.  Bad news is I don't think it is installed properly and it was done with copper...good news is that Jstar is coming over take a look at it next week.
    Steamhead Member Posts: 18,271
    Where to start?
    I see a bunch of issues right off. But if JStar is coming, he'll get you straightened out.
    Consulting
  • SWEI
    SWEI Member Posts: 7,348
    edited January 2014
    Just for fun
    I started making a list.  Keep in mind that while I'm pretty good with hot water, I have limited steam experience.
    Clearly wrong:
    Copper steam pipe.
    Missing riser from second boiler tapping.
    Insufficient "A" dimension.
    No piping from PRV outlet.
    Possibly wrong:
    Improper Hartford loop (can't see thanks to camera angle.)
    Undersized header piping.
    Not sure what the skinny copper line leaving the header is (Pressuretrol?)
    Whatever the issues, Joe will set you straight.
  • ChrisJ
    draft hood
    Besides the horrible steam piping, are there two draft hoods!?!?!
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,919
    Draft Hoods
    Yes, there are two of them. So the vent damper (if that's what I'm seeing) isn't doing much good.
  • ChrisJ
    Amazing
    This might win the "piped wrong" award. Not only is the steam piping wrong but they somehow managed to mess up the flue as well. Can't blame that on someone that only knows hot water systems.
    Obviously done by someone who had no business touching any heating system.
  • viali8
    piped incorrectly
    Thanks for the feedback guys.  I figured that this was not installed correctly.  Ignorance is expensive...when I went to go see the house I knew zilch about steam heat.  If I knew what I know now I would have had the seller give me a credit...anyway it needs be taken care of. JStar is coming out next week so I hope he can help me out.
    That skinny copper pipe coming from the header is for the automatic water feeder.  Should it be there?
    Matt
  • SWEI
    Automatic water feeder
    definitely not!
  • viali8
    bad piping
    I have been using he boiler like this for a couple weeks.  it still produces some heat.  Jstar isn't coming until next Monday.  Do you think I am doing serious damage to the boiler by using it when its piped the way it is.  I have the temp. set at 55 during the day and 63 when I get home in the evening.  Should I shut it off and spend time at a relatives house until Jstar comes over?
    Matt
  • BobC
    BobC Member Posts: 5,546
    nothing will happen
    that hasn't happened so far. Steam systems are rugged and the question is how much harm has been done in the years since that was installed. Anything from now till next week is inconsequential.
    Let it do it's best to warm the place up.
    Bob
    3PSI gauge
  • viali8
    sounds good
    The boiler was installed right before I moved into the house.  Not more than 4 weeks ago.  Actually the boiler wasn't even used as the previous owner moved to Oregon and had someone install a new boiler in preparation to sell the house.
  • hope you
    Hope u can go after the installer and make them pay for the repiping job.. that installer have no business of installing boilers.
  • todd_ecr
    todd_ecr Member Posts: 92
    IOM
    I've attached our IOM for the PEG-E steam boilers.  Pages 10-11 show the near boiler piping diagrams.
    It makes me cringe to think of what might be happening when that water feeder kicks in...
  • viali8
    thanks!
    Thanks for the PDF file!   I am no genius but my the way my boiler is piped is not even close to what it looks like in the diagram.  Damn this pisses me off....the screwed up thing is that my realtor recommended a few guys to take a look at the boiler.  I contacted one of them and obviously received bogus information.  No I have to pay for it :(
  • keep
    Keep bugging the Realtor... give him or her guilt trip for having you go thru major expenses by having these kunkleheads check out ur system..
  • JStar
    JStar Member Posts: 2,752
    Steam
    Those pictures are so hard to look at. So many issues....
    All realtors have a crew of goonies to do their assessment work done quick and cheap just to sell the house (in fact, we do this type of work for several realtors). But, I would be upset about this, too.
    Steamhead always says that you can't fix stupid, but you can certainly fix stupid work. Not all is lost....as long as the boiler is the right size.
  • viali8
    steam
    I will confirm what model the boiler is.  I am pretty sure I can access some PDf files from the Utica website with some helpful information.
    Matt
  • JStar
    Update
    Well, this mess was finally cleaned up today.
    We replaced all of the piping. Corrected the bad venting connections. Added a massive amount of main vents. And installed a 2-stage GCV with Vaporstat to run on High/Low. After firing, the 60-70ft main was hot in under 5 minutes.
    Now that's some nice work
    but we shouldn't be surprised, should we?
    JStar, what turn-down are you using on that 2-stage valve?
    Consulting
  • JStar
    Gas Valve
    Low Fire is 60%. It is non-adjustable as far as the manufacturer says. Though, I'm sure there is a way to adjust it with a new spring under the Low Fire solenoid valve. However, 60% seems ideal for steam because Low Fire almost always matches the connected EDR load.
  • jonny88
    jonny88 Member Posts: 1,139
    nice install as always
    one question about venting.Is it ok to wye the venting for both units or should they have seperate penetrations.I get a lot of conflicting answers.Thanks .
  • Hap_Hazzard
    Nice job!
    Everything looks great, but I especially like the header. You are a genius when it comes to designing effective headers in cramped spaces.
