Air to water heat pump options
Bart Vaio
Member Posts: 56
Just saw a post in the heat pump section regarding options for air to water hydronic heat pumps. I am well versed with the Daikin Altherma's and I am a big fan. Are there any other manufactures offering product for the US market yet? Is Unico offering their reverse cycle chiller? I had recently read an article by Siggy and he remarked that there were 6 manufactures offering air to water heat pumps for the US market.
There are several.
SpacePac has a reverse cycle chiller that I installed in a hydro air system.
Electro makes one that uses a conventional heat pump with electric boiler backup.
I think Daikin has a high temp one over in Euro. It only does heating which I assume is probably due to 2-stage vapour injection refrigeration. Just a guess.
There's not a very big selection and they all like low water temps.
By the way. That SpacePac that I installed. I put a KW meter on it (the whole system). The one like the Utility Companies use. At 9 cents a KWH the operating cost for a whole year, heating and cooling, was just a scudge over $800. Not real shabby. I have the heat set up in 5 stages and 2 stages for cooling.
Harvey0
- 120 Geothermal
