does all the heating pipe have clamp?
magic90015
magic90015 Member Posts: 26
hi.
so if there's loosen clamp of the pipe and that makes noise.
does all the pipe have clamp and if they are not loosen,
do they all stay still even like when someone try to push the pipe if it raddles or not? and if it pushes when someone push does that mean the clamp is loosen? what I noticed in this apartment was only one heating pipe was still when I pushed. and most of the all was moving when I push. Is this normal? Thanx!
  • delta T
    delta T Member Posts: 884
    What kind of
    Heating pipes where? can you post a pic?
  • M Lane
    M Lane Member Posts: 123
    Heat water pipes
    will expand and contract significantly. Ideally, the installer should use means of support that will allow the pipes to slide back and forth within them. Expansion is such a factor that on bigger jobs we have to pipe U-shaped loops in line to accommodate expansion sort like a bellows.
