tankless water heaters
clammy
clammy Member Posts: 3,255
We install only a very few each year and have not relly had much issues or complaints,but i am wondering how these unit fair on suppling hot water to the newer he washing machines which feed hot water in a metered fashion on n off till the machine senses the correct water level that i needs .just wondering how much of  a sandwich of cold there is and as we all know short cycling of anything is not a good thing but watching my own washing machine operate has me thinking peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
  • M Lane
    M Lane Member Posts: 123
    Answering your own questions
    I think you know the answers. I have a Noritz NC 111. The HX holds probably about a gallon, which seems to cool off faster than the water in my pipes. So every draw for hot water that is more than 5 minutes out from the last one involve close to 2 gallons of cold, which is a problem for washers. We all know that the only cure for that is storage, either circulated or heated as in a water heater. At this point you are not talking energy savings at all, just decadent unlimited hot water. Thats what I tell all my clients and usually end up putting in a 50 gallon, 65,000 water heater with high temperatures and a mixing valve.
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    Internal heating element
    When facing this problem upgrading the washmachine to one with its own heating element may be better than installing a "Buffer" tank.. Bosch/AEG/Miele/ASKO/ are some of the Manufactures that offer these Machines..
