extrol chge
Paul_69
Member Posts: 251
in Oil Heating
can a extrol tank increase in air pressure by itself on system or would someone have to pump air in? i have from time to time found more than 12 psi in tanks when dropping system to 0 psi to check and had to lower them on single or two story homes.
They may have been
over-charged at the factory and the original installer did not check for proper pressure.All Steamed Up, Inc.
Consulting0 -
extrol
always told you can check pressure in extrol if system is dropped to 0 psi. is it better to pull tank off system?0 -
I like
I like an isolation valve between the expansion tank and the system and a boiler drain between the expansion tank and the isolation valve. You don't want any water pressure on the tanks bladder to influence the air pressure.0
- 120 Geothermal
