steam supply packing nut
quack24
quack24 Member Posts: 74
Hi guys I was repacking a stem valve on a steam supply and I apparently tight end it down a little too much and the center of the nut broke off does anyone know where I can get a new (old ) nut from?
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,917
    I might be able to help.
    I've had terrible luck with radiator valves. I can never get spuds out of radiators or get the disks off to replace them, but for some reason I kept the packing nuts. If you can measure the stem diameter, inside diameter and thread pitch I'll see if any of mine will fit.
  • quack24
    thanks
    But I probably won't be able to measure it as its in an apartment that I do the repairs in for now I put the piece that broke off in the nut and replaced it so its holding for now but I figured if I can get a whole bunch of different sizes next time I get in that apartment I'll haveone that fits
  • quack24
    i am going to
    Try and see if I can get any old ones for houses being demolished as a friend of mine does demolition I really wanted to find out if there is a place I can buy a couple of each size to have around
  • Hap_Hazzard
    A couple of each size would be a lot.
    There are quite a few different sizes and styles of these. I don't know if it would be possible to get one of every size and shape.
    But if you know someone who does demolition on houses with steam heat, you should try to get ahold of some radiators. Most people don't realize that there's a market for cast iron radiators and sell them for scrap.
  • quack24
    ill ask him
    What he does with the radiators if I can get some some I'll post them here
  • quack24
    edited January 2014
    if i wanted to measure the
    Size how would I? By the way I had very good luck cutting the spuds flush with the radiator and two or three cuts then knock the pieces out with a screw driver just be careful you don't over cut and ruin the threads
  • Hap_Hazzard
    Measuring
    I'd use my digital calipers for the stem and ID and a thread pitch gauge for the threads.
    I don't have trouble getting the spuds out. I just have trouble getting them out in one pice and usable condition. Most of the pros here can salvage them more often than not and it drives me crazy that I can't seem to do it.
  • quack24
    edited January 2014
    oh
    Out of the dozen or so I tried I only got one out in usable condition and I don't have either the calipers or a thread gauge so I guess its another shopping trip to Amazon. Just curious if the hole for the stem is too small can it be drilled or put a washer if it is too big
