Solar danger....
kcopp
kcopp Member Posts: 4,663
Saw this today...
<a href="http://boston.cbslocal.com/2014/01/09/i-team-the-hidden-dangers-of-solar-panels/">http://boston.cbslocal.com/2014/01/09/i-team-the-hidden-dangers-of-solar-panels/</a>
  • SWEI
    SWEI Member Posts: 7,348
    There has been plenty of heated discussion
    in the industry about this over the past decade.  There are clearly some real issues. There are clearly some non-issues.  Hot air continues to emanate from every discernible  direction.
    I believe the NFPA can handle this one.
  • This content has been removed.
  • Gordy
    Gordy Member Posts: 9,546
    Back when TJI, and BCI floor joist were introduced no one ever thought about how little wood there is in case of a fire. They were great in spanning long distances with out support beams, and knock outs for plumbing, electrical, and even hvac.
    Fire fighters realized that the potential of an unstable floor in the event of a fire. People still use them.
  • kcopp
    actually the fire depts. still lobby against a lot of things. Trusses. tji. etc.
  • icesailor
    icesailor Member Posts: 7,260
    edited November 2014
    And the Fire Nazi's lobby for residential fire sprinkler systems in areas with only private wells, and 5 GPM pumps or well production. That's 300 Gallons Per Hour.
    If you read everything those doom and gloom terrorists propose, you'd be heading for the bed, getting under a blanket, and hoping that you never woke up.
