taking apart/reassembling radiator: old RED radiator goop?
Hey all, got a question that I don't see anywhere.
Had to take some radiators apart to get downstairs out of a house, going to another house.
Now my question.
Years ago I worked with a ancient aged old real-true boilermaker pressure pipe fitter, my first experience of putting a radiator back together.
He had a can of RED colored horrible stinking goop that was brushed onto each push nipple.
I remember that the can actually had a picture of a Boiler and a Radiator on it, and on many radiators that I've taken apart I have seen hardened RED gunk on/around the push nipples.
I've also seen residue of it on the thread connections on old boilers systems
Obviously, it's an old product, but cannot be too old since I first saw it only about 10 years ago.
I figure, it must work, and must work well to last so long, just don't know if anyone here knows where/if I can get this stuff.
Otherwise does anyone have an alternate product/goop to seal around push nipples?
Thanks
  • Robert_H
    Robert_H Member Posts: 238
    Old Rad Dope!
    The same stuff was on the rads I rebuilt this summer. on the new push nipples i used Pro-Dope and they all held 60psi for a few hours.  Although they will see hot water "finally" some time in the next week.
  • ScrewLoose
    ScrewLoose Member Posts: 20
    Well, some info...
    I think the company  that made the product I once used is gone.
    However I think I found what the general name for such a product s called.
    Gasketing Cement.
    Jointing Paste (or Compound)
    I have found TWO products that apparently are similar and are used on radiators with great success.
    Utility Wonder Products: Blue Seal Thread and Gasket Sealant.
    STAG Jointing Paste - Type -B- RED (which is apparently unavailable for sale in the USA) but is the most similar to what the "old guys" would have had in their tool boxes.
    Well, at least I can get the Blue Seal...
  • SWEI
    SWEI Member Posts: 7,348
    Might be
    an anaerobic thread sealant (think Loctite.)
