Gas/hot water Heating battery backup
edgreenberg
Member Posts: 2
in Gas Heating
We have natural gas, hot water heat in our 1500 sqft ranch home in upstate New York. We have two zones and two circulators. We don't have a generator. Last night, the power went out for a few hours, and while it was out I was thinking of how I could battery back up the furnace.
I would need to run two circulator pumps, the furnace itself, and optionally, the (gas) hot water heater. My expectation is that all the furnace needs electricity for is ignition and a pump, not a fan. Then two circulator pumps. I really don't (yet) know how much power we're talking about, but I think it lives on one 15 amp breaker.
I envision a bank of RV batteries and a UPS charger/inverter.
I also wonder how reliable the gas supply is when the power is out. I have a question in to my gas/power company, National Grid.
Am I out of my mind?
Thanks,
Ed Greenberg
Thanks,
Ed Greenberg
Not out of your mind
but you will need a pretty decent sized inverter to supply the power required, and it probably will need to be one which gives good clean power (not all of them do). I believe that UPS devices which can supply that kind of load do exist, and might be the way to go -- although most of them are designed to give you enough time to gracefully shut down your system, rather than power it for any length of time.
Do your wiring carefully -- if you don't use a UPS which floats on the system all the time, you will need a changeover switch just like any other backup power system.Br. Jamie, osb
Maybe an RV converter/inverter
Once I calculate the power load, I was thinking of an RV style battery charger/inverter.
As far as wiring is concerned, that's why they make electricians
Thanks,
Ed0
