Spill Switch Not Attached / Dangling
Larry1
Member Posts: 6
in Gas Heating
I was recently poking around my newly installed boiler, and noticed something dangling at the end of two wires. After emailing my plumber and looking around online, I found out that it is a blocked vent switch aka spill switch. Looking at the back of the boiler, I think I can see where it goes. The metal flange is still there and still screwed in. Looks like I could reattach it pretty easily.
My question is, once I attach it, is there any way to test it to see if it's working?
It's a Burnham Independence IN-6 steam boiler.
Thanks,
Larry
Thanks,
Larry
First
Thing is if this is a new boiler, why is this switch not installed properly, this is extremely life threatening, in the event of high CO and flue spillage. install the switch and have a professional come and check the system for proper draft and perform a combustion analysis with a digital combustion analyzer. worst case scenario, when the boiler was installed and the installer fired up the boiler there was flue spillage, and he disconnected the switch because it kept tripping, if you install that switch and it trips and shuts the boiler off , then you know thats what happened during the install. testing the switch, i guess you can heat it up and see if it trips thanks
Paul SASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Paul S
Is 100 percent correct on this... makes us wonder if the near boiler piping done correctly too.. take some pictures and send them here..0 -
Bi-metal swwitch
If it is just a cheap bi-metal switch, they are known to fall apart sometimes (which sounds like what happened here). Call your installer and have it replaced.
Rob0 -
It happens
Agree with last post…Don’t panic just reattach it or have installer reattach it….It opens on heat Unlike a roll out sw. spill sw. is resettable..BUT DONT RESET IT YOURSELF…CALL A PLUMBER OR GAS FITTER…..0 -
Where are the wires?
Where there any wires connected to the switch? It sounds like they forgot to install it. It is very obvious where it goes but what happen to the wires?0
- 123 Chimneys & Flues
