New homeowner needs help
TAThomas
Member Posts: 1
Hello everybody,
I am just 22 years old and don't know much of anything about boiler heating systems. I just bought a house with an old coal boiler which I believe was converted to gas. I have been told it was a steam system. As I have been searching online I can't figure out what kind of system mine is or what kind of radiators I have. It has two pipes coming up through the floor side-by-side on the bottom that consolidate into one that go into the radiator. I will attach some pictures that will hopefully help identify what I've gotten into. I would appreciate some knowledge on my situation! Thanks!
Those look like
Honeywell Unique valves. See p. 12 of http://www.heatinghelp.com/files/articles/1014/105.pdf and see if you can find something near the boiler that looks like the item on the preceding page.0 -
I Worked On A System Like That
In Arlington, Ma., it was forced hot water, and we came to the conclusion that it was similar to a mono-flow system, the system was still working great after many, many decades of use.
Thanks, Bob GagnonTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Steam?
Usually the vents for steam radiators are more in the middle, not the top as shown. Also, we usually see a atmospheric vent on steam radiators (looks like a large bullet).
Go to the boiler and look for a sight glass (a glass tube that shows water level).
I'm leaning towards hot water, not steam.0 -
Unique hot water system
I'm sure you have a hot water system. Pictures of the boiler, and it's piping would confirm or deny this.
There are some excellent books in the shop here which will give you the background information you need to keep your system running well at peak efficiency.
Key maintenance areas would be:
1.clean, well adjusted burner.
2.air bled out of the radiators.
3.thermostat installed correctly, with settings for hot water.
4.aquastat , and system pressure set correctly.
A hydronic tech can show you what you can do yourself in the way of routine maintenance.--NBC0
