Looking for resources
youngster_plumber
Member Posts: 2
I am looking to see if anyone had a good recommendation for resources regarding new high efficiency condensing boilers. Troubleshooting guides, parts list, etc.
you
Can pretty much, just go on the manufactures website and download the installation manuals, theres a bunch of other stuff you can download too... Paul SASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
RPA
This would be a good start
http://www.heatinghelp.com/forum-thread/148442/RPA-College-of-Hydronic-Knowledge-and-Dave-Yates-debuts-new-online-course"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
There's Much More
About high efficiency systems then the boiler, The Boiler is just a heating plant that makes energy. As others have said all that information is available on the boiler mfgs web site.
I'd say, that the design side is even more important then the plant itself but to be a good designer you need to understand hydronics. I'd suggest you start with these great tools from our friends at Caleffi. These great resources should be on every professionals bookshelf.
http://www.caleffi.us/caleffi/en_US/Site/Technical_library/Idraulica_magazine/index.sdo
Another suggestion is for you to join the Taco Flo Pro Team and John Barba's Neighborhood at www.taco-hvac.comThere was an error rendering this rich post.
- 62 Biomass
