Electrical box behind t-stat
ChrisJ
Member Posts: 17,383
What is the proper way to install a home thermostat. Just run the wire through a hole in the wall and screw the thermostat to the drywall / plaster. Or, to install an electrical box to mount the thermostat to?
I'm assuming electrical box is the way to go for a clean install but have no idea which is why I'm asking.
I'm running a new line tonight and figured I should clean things up while I'm at it. Right now its just a hole in the wall.
As always I appreciate your help!
If this is a low-voltage retrofit
Try an "old work" plaster ring.0 -
Yep
Sorry, yeah its a 24V thermostat in my home.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
include some extra conductors
even if the stat you have only needs two wires, use a 4 conductor so you have spares, or the ability to upgrade to an Ecobee or Nest some day.
On radiant jobs I would install a box with a flex condiut to the mechanical room. That allowed you to add a slab sensor, outdoor sensor, or just give you future options.
That inexpensive plastic flex condiut is perfect, t-stat wire slides into it easily.Bob "hot rod" Rohr
Yep
That is actually the reason I'm running a new line. When I put the boiler in I used a 2 conductor. Now I'm ripping that out and running a 4 conductor so I can have a common.
Thank you all for responding.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
If you're pulling new wire
Throw in a run of CAT5e along with the thermostat wire. Newer controls tend to like twisted pair (and you never know where this is going)...0 -
cat5e
I wouldn't mind doing that.
However is there any hope for my steam boiler to have such a control in the near future?
I'd love an outdoor reset but it seems like all of the main companies couldn't care less for us steam guys.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
