Electrical box behind t-stat
ChrisJ
ChrisJ Member Posts: 17,443
What is the proper way to install a home thermostat. Just run the wire through a hole in the wall and screw the thermostat to the drywall / plaster. Or, to install an electrical box to mount the thermostat to?
I'm assuming electrical box is the way to go for a clean install but have no idea which is why I'm asking.
I'm running a new line tonight and figured I should clean things up while I'm at it. Right now its just a hole in the wall.
As always I appreciate your help!
  • SWEI
    SWEI Member Posts: 7,342
    If this is a low-voltage retrofit
    Try an "old work" plaster ring.
  • ChrisJ
    Yep
    Sorry, yeah its a 24V thermostat in my home.
    hot_rod Member Posts: 27,570
    include some extra conductors
    even if the stat you have only needs two wires, use a 4 conductor so you have spares, or the ability to upgrade to an Ecobee or Nest some day.
    On radiant jobs I would install a box with a flex condiut to the mechanical room. That allowed you to add a slab sensor, outdoor sensor, or just give you future options.
    That inexpensive plastic flex condiut is perfect, t-stat wire slides into it easily.
  • ChrisJ
    Yep
    That is actually the reason I'm running a new line. When I put the boiler in I used a 2 conductor. Now I'm ripping that out and running a 4 conductor so I can have a common.
    Thank you all for responding.
  • SWEI
    If you're pulling new wire
    Throw in a run of CAT5e along with the thermostat wire.  Newer controls tend to like twisted pair (and you never know where this is going)...
  • ChrisJ
    cat5e
    I wouldn't mind doing that.
    However is there any hope for my steam boiler to have such a control in the near future? :)
    I'd love an outdoor reset but it seems like all of the main companies couldn't care less for us steam guys.
