1990 elect 80 gallon water heater ? should I chg it
ok i put this in my house in 1990..I have cleaned it out thru the element hole a few times...chgd the lower element once...it works great...when we are gone for a week and shut it off the water is still warm when we return...so...are we on borowed time ??? Is there anything I should be doing to help it not devolpe a leak ??
I think its a Craftsmaster and its 80 gallon on a night meter
  • SWEI
    SWEI Member Posts: 7,342
    Check the anode(s)
    and drain it.  See what you find.
