Blower motor for Temco Pre-Vent Heater Model GSW 30-2
Frozen
Member Posts: 3
I have a Temco gas fired GSW30-2 heater.
Of course the motor burned out and naturally, I threw it out!
Now I'm trying to replace the 3 speed Fasco blower motor but don't have the model number.
I don't want to replace the heater as the venting would require siding work.
This is not an option as the house is going up for sale and additional work is not what I'm looking for.
Help and Thanks in advance.
I called Fasco, but they were like deer in the headlights.
I can pretty safely tell
you that the motor is no longer available. I have information (Manuals) on the Temco DSW 50-2 and the DSW 85-2 which used a double shaft motor and those motors we had to have rebuilt here locally in RI as Temco no longer had them available back 20 to 25 years ago.
It is too bad you threw the motor away as motors can often be rebuilt for a rather small fee.0 -
Motor Madness
Thanks Tim,
I replaced the original Fasco blower motor with a single speed Fasco I had laying around. It was a perfect fit in every way except the single speed has lower RPM's than I need to circulate the air around the room.0 -
Motor Madness
Thanks Tim,
