snap in foam insulation
greenhead_2
Member Posts: 13
has any body had a problem with this type of insulation not having a big enough r valve at (8) or the foam insulating the tubing too. Thermo snap is the product name
It wont meet code for slab insulation.
If thats what your asking. energy code requires r 10. I prefer EPS or XPS with mesh and ties.0 -
Also
it puts the tubing at the bottom of the slab. You want it near the middle of a 4" slab (or 1-1/2" from the top of the tubing to the top of the slab.)0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
