Valve Leaking
ALIGA
Member Posts: 194
I have a valve leaking, pic attached.
I tried tightening the nut, still leaking.
Is there a replaceable part there, if i take it apart? Or do I have to replace the valve.
Thank you.
Thank you.
Try fixing it first...
If I remember right, there is a gasket under the bonnet--or there was in the valve I took apart. If you can loosen the bonnet, but can't find a replacement gasket, I'd suggest using some water pump RTV silicone (available at your local auto parts store) to form a gasket. I've used without any problem as a gasket on the dirt pocket of a low water cut-out and to seal a leak from a bolt on the heater cover plate of my steam boilers.
Chris0 -
lamp wick
Lamp wick works very well fot this application. I've done the lamp wick trick more times then I can remember with a near perfect success rate.0 -
I took it apart, added some teflon tape
lets see if that holds.
thanks chris and aaron.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
