Valve Leaking
ALIGA
ALIGA Member Posts: 194
I have a valve leaking, pic attached.
I tried tightening the nut, still leaking.
Is there a replaceable part there, if i take it apart? Or do I have to replace the valve.
Thank you.
  • Chris_L
    Chris_L Member Posts: 354
    Try fixing it first...
    If I remember right, there is a gasket under the bonnet--or there was in the valve I took apart.  If you can loosen the bonnet, but can't find a replacement gasket,  I'd suggest using some  water pump RTV silicone (available at your local auto parts store) to form a gasket.  I've used without any problem as a gasket on the dirt pocket of a low water cut-out and to seal a leak from a bolt on the heater cover plate of my steam boilers.
    Chris
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,651
    lamp wick
    Lamp wick works very well fot this application. I've done the lamp wick trick more times then I can remember with a near perfect success rate.
  • ALIGA
    I took it apart, added some teflon tape
    lets see if that holds.
    thanks chris and aaron.
