Old School Insulation
Question for you old timer pros (or anyone else that knows the answer)
When insulation fittings, and covering pipe insulation with premixed high temp cement, do you mix it with water, or leave it thick? If you mix your own, do you leave it real think like playdoh, or a bit more runny? Is thinner weaker? Better?
