Old School Insulation
MDNLansing
Member Posts: 297
Question for you old timer pros (or anyone else that knows the answer)
When insulation fittings, and covering pipe insulation with premixed high temp cement, do you mix it with water, or leave it thick? If you mix your own, do you leave it real think like playdoh, or a bit more runny? Is thinner weaker? Better?
i use
I use cold water paste with cheese clothes0 -
Thick
So like think enough to be able to slightly mold in your hands?0
- 119 Geothermal
- 394 Solar
