Help with 90 year old coal converted to gas (steam)
ESB
Member Posts: 1
Everything has been fine until this October. Heat did not go on; pilot was off. Heating company came and fixed. Ok for day or 2. Thermostat set for a constant 68 24/7. Not maintaining temperature. Put in a new thermostat White Rogers 1F80-361. Ok for a few days. Seems to be fine during day and early evening. From 11pm on, temperature in house drops to 66 with thermo set for 68, and furnace does not fire up. Still freezing in house at 6am- up thermo to 71 and furnace fires up.
HELP...
HELP...
if you jump the wires at thermostat
does the unit turn on?
if so, the thermostat may be bad.0 -
generator
I have a 80 year old boiler where I live. First off, hate it, wish my land lord would replace it but I digress. I know mine has a generator that is powered by the pilot light. It kicks everything on and off. Maybe the problem is down there. I know my land lord had to have someone work on it last year because it caused problems with the boiler firing up. I wish you the best to get your heat back!0 -
80 year old boiler
Why do you hate it so much?
Landlords need to provide adequate services. Is it not providing proper heat?0 -
Memory
Going off of memory here but I think the boiler JH is talking about is a snowman, and is grossly oversized.
If that is the case he is justified in hating it.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Thermopile
What JH is referring to is a Thermopile. Does your system have one of those?0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
