heater/thermostat issue?
gook
Member Posts: 1
in Gas Heating
When I turn the thermostat on the heater comes on, works fine until it reaches the temp that it's set at and then turns off normally, just like it should. But it will not turn on again when the house temp falls below the temp set on the thermostat. The only way to get it turn on again is to turn the thermostat off and back on and it works "properly" again until it heats the house to the right temperature, then turns off "properly", but never comes on again. The thermostat is a programmable type thermostat and is 13 years old. Is it the thermostat or something in the furnace? It is a natural gas, hot air heater.
Thanks.
Thanks.
The Issue...
Requires a meter and someone with the knowledge of how to use it. It could be in the furnace and it's locking out or it could be the thermostat or wiring. You need a tech on site.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
