Basic Safety Question
BrianH_1978
Member Posts: 5
Hi,
I have a single-pipe steam system, and I bought some adjustable air vents to replace
the existing vents which are not adjustable (and probably needed replacing anyway).
From a safety perspective, I should be ok just closing the supply valve for each radiator
as I go, right? I don't need to shut the whole system down?
Thanks in advance for any advice/tips!
Changing valves
You could flip the switch on the boiler as well. Sometimes the valves do not close all the way.--NBC0 -
Let sitting dogs lie
I would just install them when the radiator was cool or just warm (with the system NOT calling for heat) if you can because you don't want to start messing with a valve that has not been used for God knows how long. Also wrap some teflon tape on the vents threads before putting them in.
3PSI gauge0 -
Thanks
Thanks guys.
It isn't too cold out today so I may as well turn off the boiler too, just in case.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
