Basic Safety Question
Hi,
I have a single-pipe steam system, and I bought some adjustable air vents to replace
the existing vents which are not adjustable (and probably needed replacing anyway).
From a safety perspective, I should be ok just closing the supply valve for each radiator
as I go, right?  I don't need to shut the whole system down?
Thanks in advance for any advice/tips!
  • Changing valves
    You could flip the switch on the boiler as well. Sometimes the valves do not close all the way.--NBC
  • BobC
    BobC Member Posts: 5,576
    Let sitting dogs lie
    I would just install them when the radiator was cool or just warm (with the system NOT calling for heat) if you can because you don't want to start messing with a valve that has not been used for God knows how long. Also wrap some teflon tape on the vents threads before putting them in.
    Bob
    3PSI gauge
  • BrianH_1978
    BrianH_1978 Member Posts: 5
    Thanks guys.
    It isn't too cold out today so I may as well turn off the boiler too, just in case.
