Steam riser: flange or coupling?
vaporvac
Member Posts: 1,520
Quick question... is it OK to use unions instead of flanges for disconnects on the steam risers? As usual, thanks for any input. C
Why not?
except for one minor detail -- how would you get it apart again if you ever had to? If you've got that one covered...Br. Jamie, osb
Meant Union!!!
Sorry, meant to write union, NOT coupling. Would that work? I need more sleep.Two-pipe Trane vaporvacuum system; 1466 edr
Most small systems use unions
Larger systems use flanges from pics I have seen0 -
in atreement
If it were my system, 2" or smaller I'd use a union. Anything larger I'd use flanges.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Flanges
Not a pro, but flanges are much easier to manage with a flange separator. Other than ease of cracking it open down the road, it can't see why one is better than the other though. All the pics of installs done right seem to use either. The old timer teaching me uses flanges, his partner uses unions. I can tell you that if unions didn't work, they would use them at all.0 -
price
that is why we use flanges over 2". Also using 3/4" wrenches is easier then the 4' pipe wrench when tightening up 4" pipe.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
