Steam riser: flange or coupling?
vaporvac
vaporvac Member Posts: 1,520
Quick question... is it OK to use unions instead of flanges for disconnects on the steam risers? As usual, thanks for any input. C
    Jamie Hall Member Posts: 26,847
    Why not?
    except for one minor detail -- how would you get it apart again if you ever had to?  If you've got that one covered...
  • vaporvac
    Meant Union!!!
    Sorry, meant to write union, NOT coupling. Would that work? I need more sleep.
  • ALIGA
    ALIGA Member Posts: 194
    Most small systems use unions
    Larger systems use flanges from pics I have seen
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    in atreement
    If it were my system, 2" or smaller I'd use a union. Anything larger I'd use flanges.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • MDNLansing
    MDNLansing Member Posts: 297
    Flanges
    Not a pro, but flanges are much easier to manage with a flange separator. Other than ease of cracking it open down the road, it can't see why one is better than the other though. All the pics of installs done right seem to use either. The old timer teaching me uses flanges, his partner uses unions. I can tell you that if unions didn't work, they would use them at all.
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    price
    that is why we use flanges over 2". Also using 3/4" wrenches is easier then the 4' pipe wrench when tightening up 4" pipe.
    cell # 413-841-6726
