How much water?
Dsisson
Dsisson Member Posts: 106
One pipe steam system. 1year old burnham boiler. Water line drops approx 1" every 2 weeks. 3 of my radiator valves have slight leaks.
Is this a normal ammt of water to add? Obviously I need to fix the valves.
    Jamie Hall Member Posts: 26,840
    It's not that evil...
    but it is more than it should be if the system were tight.  I wouldn't be that surprised, though, if fixing the leaks on the valves made a big difference.  Surprising how much water a "slight" leak really is!
