Effluent lift station
turn the
Turn the check valve. 180 degrees..0 -
Joking?
You're joking, right?0 -
nope
Why would I be kidding?0 -
Because turning the valve...
would let the flapper thingy lay flat and make the valve pointless-no?0 -
(To Everything) Turn, Turn, Turn:
Or turning it end for end makes the check flapper swing against the flow.0 -
There are only two ways
to stop the bang -- it's water hammer, of course. The first may not be effective -- it often isn't -- but if the flow is low enough you may be able to stop it with a standpipe (I don't suggest something like a Well-X-Trol on effluent). More likely not. The preferred route is a slow closing check valve. There are a variety of these out there, depending on size.Br. Jamie, osb
- 50 Industry Classes
