Pipe Dope&Tape:Is this OK?
vaporvac
Member Posts: 1,520
For the new install...No one had Megalock sealant, so we bought TFE pipe sealant with PTFE from Grainger. It says it's good for steam...anyone have any experience with it? I also bought Rectorseal, but noticed afterwards it's not good for pipe over 2" and all my piping is 31/2" and 4".
We also bought Loctite Quicktape249 teflon tape(from Grainger) as well as Oatey Blue Megatape 30621(from Home Depot). The former was about 10x the price. Is it that much better or is the Megatape OK for the piping? Thanks for all the help everyone. Hopefully, we won't be shivering too much longer. colleen
Blue Monster
I used Blue Monster bought at Lowes on the repairs I did and I really liked it. You can get it in 1" wide rolls which is nice for big stuff. I used the sealant with it too but it hasn't been on long enough to know if it truly stays soft. So far after 2 months it's about like it was when I applied it. It hasn't hardened at all but 2 months isn't long enough to know for sure. I buried the pipe the exact amounts listed on the charts and the tape and sealant held for every connection without a single leak. I'm not a pro though and they might feel differently about this stuff.0 -
Thanks.
Thanks for replying. I don't need it until Friday so I'll see what others suggest and maybe check it out then, unless they're open on Thanksgiving. I'm normally really against that, but this year I feel differently! I was a bit gasping at the price of the Loctite stuff so I'd be happy for a cheaper option, especially 1". What I bought was only 1/2". What sealant did you use? Did you buy it from Lowes as well?
The guy at HD said I was getting my money's worth out of him!Two-pipe Trane vaporvacuum system; 1466 edr
Same Brand
I used the Blue Monster sealant as well. They had several kinds but the one I got was called Anti-Seize Nickle I think. It's a high temp version of their sealant. It cost a lot more than the regular stuff but I only needed one bottle. The Blue Monster regular sealant could easily handle steam temps so you would probably be fine using it.0 -
Anaerobic sealants
are available from quite a few companies. Loctite has a big advertising budget.
http://www.fppi.com/products/list/139/pipefit-as-thread-sealant-paste.aspx is rated to 400ºF and is priced right.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
