Effluent lift station
bill_105
bill_105 Member Posts: 428
Can someone offer some tips on making a lift station pump not go bang when it stops.
  • turn the
    Turn the check valve. 180 degrees..
  • icesailor
    icesailor Member Posts: 7,260
    Joking?
    You're joking, right?
  • nope
    Why would I be kidding?
  • bill_105
    Because turning the valve...
    would let the flapper thingy lay flat and make the valve pointless-no?
  • icesailor
    (To Everything) Turn, Turn, Turn:
    Or turning it end for end makes the check flapper swing against the flow.
    Jamie Hall Member Posts: 27,392
    There are only two ways
    to stop the bang -- it's water hammer, of course.  The first may not be effective -- it often isn't -- but if the flow is low enough you may be able to stop it with a standpipe (I don't suggest something like a Well-X-Trol on effluent).  More likely not.  The preferred route is a slow closing check valve.  There are a variety of these out there, depending on size.
