Glowcore
Alan_6
Member Posts: 87
Does anyone run across Glowcore anymore? Most of the boilers are out of the field now. I found cracks in a heat exchanger today, on a glowcore furnace. Is there any parts available for these furnaces? Does anyone know who the manufacture was. This one looked alot like a Tempstar, or a Whirlpool, from the late 1980's.
cracked heat exchanger
The time spent trying to find the company and if you accually get a heat exchanger to buy, calculate labor to tear furnace down install new exchanger put it back together again it might not be worth it, maybe cheaper to get a new furnace even if you really like the one you now have.0 -
I've never seen one, but
someone on this forum recently posted that a customer had one that broke down every year. He kept it going, but the customers complained because it broke down every year. The heating guy then told them that he "never wished to work on the Glow Core again," but would be glad to install a new system instead.0 -
Glowcore
Heat exchanger still available through a company in Texas that bought the rights to the boiler. Sorry but I can't fing the name for you, but a little research will get it for you. installed an exchanger for a customer last year, but he got the thing elsewhere. Quite sure you can find it if you try.
Sorry I can't help more
glowcore web site
Found it! Try www.glowcoreac.com
Thanks for the web site. I am not looking for the heat exchanger, the customer is convinced to upgrade to a high efficiency. I was just curious, if there was a way to parts like a draft inducer, burners, etc. , the o.e.m. kind of parts. I hate to tell someone that parts are obsolete, and have someone else come along with them.0 -
glow core
I have an inducer in stock if anyone is in need. Special ordered in for a cust who changed his mind.0 -
Glowcore heating system free for the taking
Recently bought house with Glowcore system hooked into solar panel. Not sure how old system is. Looking to dismantle and remove. All parts/2 spare storage tanks/copper pipes/fan boxes everything connected to system free for taking.0 -
where you....
out of?0 -
old BAD memories
Those are a real head ache. We had a couple that had a similar problem breaking down. Then found they were installed wrong They needed TWO large bTacos or grundfos pumps in series on a 1-1/8" main and the indirect water heater for it needed dual coils 1" I think. The water must move very fast through the heat exchanger or it will get too hot...But they did have a good tech line. Thjis was about 15 years ago....The customer said he used one on a pool heater and it worked great, because it had a big load.0
