pipe size
tmc
tmc Member Posts: 12
I'm replacing a gravity water boiler that has a 3''main with a forced hot water boiler, can I tie into it with 11/4 coming off new boiler?
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    In a word...
    Yes.
    Follow the installation instructions.
    ME
  • Paul S_3
    Paul S_3 Member Posts: 1,291
    system
    Are they orifice plates in the radiator valves....??....Paul s
    ASM Mechanical Company
    Located in Staten Island NY
    347-692-4777
    ASMMECHANICALCORP@GMAIL.COM
    ASMHVACNYC.COM
    https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
  • icesailor
    icesailor Member Posts: 7,260
    Flow plates:
    If you are running gas as a cold start, why would you use them? Let 'er rip. And/or use ODR. If you're using an indirect water heater off the boiler, use an "I" series 4-way mixer. The house will heat like it was designed to do when the heat was installed.
  • tmc
    pipe size
    if so ?
