pipe size
tmc
Member Posts: 12
I'm replacing a gravity water boiler that has a 3''main with a forced hot water boiler, can I tie into it with 11/4 coming off new boiler?
In a word...
Yes.
Follow the installation instructions.
METhere was an error rendering this rich post.
system
Are they orifice plates in the radiator valves....??....Paul sASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Flow plates:
If you are running gas as a cold start, why would you use them? Let 'er rip. And/or use ODR. If you're using an indirect water heater off the boiler, use an "I" series 4-way mixer. The house will heat like it was designed to do when the heat was installed.0 -
pipe size
if so ?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
