Good Advice?
Robert O'Brien
Robert O'Brien Member Posts: 3,584
<a href="http://www.blog.pexsupply.com/how-to-choose-a-new-boiler/">http://www.blog.pexsupply.com/how-to-choose-a-new-boiler/</a>
  • Canucker
    Canucker Member Posts: 723
    I suppose
    The btu per sq. ft rules of thumb will be helpful for people who live in tents
    You can have it good, fast or cheap. Pick two
  • MDNLansing
    MDNLansing Member Posts: 297
    Doing This Now
    I am designing and sizing a new boiler for my home. This article isn't accurate enough to be the only factor, but it's a good place to start. I live in a cold climate and if I use their figures my boiler is way over sized. There are many other factors to consider and using a simple EDR per Sq Foot calculation is far too simplistic. The EDR of your home will vary based on things like steam or water, insulated piping, system design and so on. I would say start with this calculation, then get more precise with specific numbers and calculations.
  • Gordy
    Gordy Member Posts: 9,546
    Of course
    Using that method will get you to buy a bigger boiler thus put more money in thier pocket.....Perfect.
    Never mind envelope construction you dont need all that.
