If our community has helped you, please consider making a contribution to support this website.  Thanks!
out door condensor/ winter storage
                    md
                    Member Posts: 24
                    I have always be told by some of the older techs  when shutting down   central air for the winter to cover the outdoor condenser , just the top not the sides to keep leaves and  heavy ice build up out,,,, and to kill power to unit, [ so oil heater does not work all winter,] then turn on a day before use and fire unit up in early spring,,,, is this a correct way  to prep unit for winter,,, thanks
            Winter shut down
That's a pretty good way to do it. But I highly recommend 2-3 days for the CCH to heat up the oil to drive the Freon out of the oil, 1 day is not enough ,especially if it is windy.0
 - 87.2K THE MAIN WALL
 - 118 Chimneys & Flues
 - 113 Geothermal
 - 164 Indoor-Air Quality
 - 73 Pipe Deterioration
 - 6.4K Radiant Heating
 - 393 Solar
 - 15.5K Strictly Steam
