I lost a job to a company that did this:
JohnNY
Member Posts: 3,231
This was an incorrect steam header repipe my partner/brother looked at and priced for the client.
The homeowner didn't like our price and called someone else who did the work in the picture for a much lower price. It still doesn't work right. Go figure.
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
I have
no idea why the pic is coming up sideways but you get the idea.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0 -
Steam
They converted the old header into a steam to hot water heat exchanger.0 -
No wonder
they got the job. Wrong is so much easier than right.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Fantastic
Thanks for the photo, it made my day. Truly a fine job if I ever saw one. At least they used pressure fittings not DWV. The worst drop header ever.
So, did you get to repipe it, or just marvel at it?0 -
piping
Copper pipe allows no swing joints which equals extra stress on boiler sections ( if sectional ) which can cause premature boiler leakingThere was an error rendering this rich post.
Get away from them ladd.
i have seen your work , that is not You.
it gets to you like it does because you know left from right right from wrong and it probably is making you sick thinking about it.
remember what i used to say Expensive is expensive , buh cheap is not cheap.
"Gui shi Gui, Piyan yi bu Piyan yi."0 -
Yeah.
The called to say they had the boiler repiped, as we recommended last year, but that the system still isn't working right so therefore our assessment that the piping was the problem was clearly a mistake.
We sent a guy to check it out and he sent that picture. We told him to run out of the house and tell them they need to call the company back that did that work and let them figure it out.
UGH!Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0 -
Nice:
Nice drop header installation.
He could have saved some more money if he had used all DWV Copper drainage fittings. It would have looked even more professionally done. By a dubber.
Simply stunning!
Does it pound?0 -
Oh, it pounds, bro.
It pounds, and it gurgles and rushes. It spits like a champ. Barely makes heat at all.
Yep. All hail the low bidder!!Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0 -
More proof
that you can't fix stupid!All Steamed Up, Inc.
Consulting0 -
Wrong advice?
I hope they will not sue you for providing a wrong diagnosis!
Customers like those are best left alone.--NBC0 -
You can fix this
Suggest they install a couple of 12 horsepower circulation pumps and just make it a hot water system0 -
I hope you
charged them accordingly for the 2 house calls !0 -
Its not that bad
They used two finger clamps on the bx line. Its those little extras that got them the job. LOL0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
