Interested in the Weil Mclain Eco 110 Boiler, why so cheap? Also, is this tankless?
iypoon
in Gas Heating
<a href="http://www.pexsupply.com/Weil-Mclain-383-800-001-ECO-110-Natural-Gas-Wall-Mount-Gas-Boiler-110-MBH">http://www.pexsupply.com/Weil-Mclain-383-800-001-ECO-110-Natural-Gas-Wall-Mount-Gas-Boiler-110-MBH</a>
I noticed this boiler was 95% efficient and 88k BTU, but it only costs $2.6k on several websites whereas a similar boiler from other companies would cost at least $1k more.
Is there anything i should know about this boiler? Does it have defects or something? Also, i can't for the life if me figure out if this is a tankless boiler or not (i kind of assumed all wall hung units were tankless, but i can't figure out based on the literature, sorry i'm a newbie). But in any case, if it isn't tankless, i do have an existing electric hot water heater i could attach this to.
not a tankless
It's less money because it is basic and barebones. They make a different unit to compete with the rest of the boilers on the market called a WM97 I believe. That has options for piping all setup internally, has an expansion tank with a valve and other options but its on par with pricing for the rest of the market. The Eco is just a heat exchanger, a control and a couple safeties, no bells and whistles.Tom
Montpelier Vt0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
- 79 Pipe Deterioration
- 396 Solar
