adding a gauge to pressuretrol
Does anyone have a picture of where a pressure gauge has been added to this configuration? In trying to get this working right my landlord wants to put in a new pressuretrol along with a good cleaning out of everything and I think I would be a good idea to have a pressure gauge as well.
  • BobC
    BobC Member Posts: 5,539
    Like this
    This worked for me but you might want to extend the gauge up a bit higher (mine has been like that for 3 years with no issues) .
    Bob
    3PSI gauge
  • ChrisJ
    ChrisJ Member Posts: 17,070
    Gauge
    Mine is basically the same as BobC's except I have my gauge up high and I have a valve to isolate the gauge from the boiler if I decide to do a high pressure blowdown.
  • JHprovidence
    JHprovidence Member Posts: 51
    that looks good
    also I wanted to switch to a vaporstat since money is being spend anyway. Is it a straight out swap or does more electrical work need to be done?
  • BobC
    easy swap over
    It takes about 5 minutes, just disconnect two wires, unscrew the ptrol and put the vstat in its place. Make sure you have contacts that break on pressure rise, mine can do either because it has both make and break options on it.
    Bob
    3PSI gauge
  • ChrisJ
    Thread sealer
    I would also recommend using teflon tape on the threads of the siphon. 4 or 5 wraps of the standard white tape should work fine.
  • JHprovidence
    thanks!
    thank you both of you for your feed back.
