Turbomax Storage - LIFO or Symmteric?
WeatherizationNYC
Member Posts: 1
<span style="font-size:12pt">Good morning,</span>
<span style="font-size:12pt"> </span>
<span style="font-size:12pt">I’m looking at two Turbomax storage tanks which were to be piped in Last-In-First-Out order, according to spec. The contractor piped them symmetrically instead. </span>
<span style="font-size:12pt">Can anyone tell me whether the symmetric piping arrangement will cause any problems, impact the lifetime, etc? Should I have him re-pipe it?</span>
<span style="font-size:12pt">Thanks in advance.</span>
Not a problem
I think a simple symmetric header will work just fine. The objective is even flow. Both piping strategies will accomplish that.
Albert Einstein0
