Which Pipe Sealant?
Black Iron
Permabond LH050You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Interesting
write up on Google search. It states that it will even seal a joint which is not fully seated due to positioning. I will have to check my local plumbing supply houses. Thanks for the reply Rich.0 -
I'm learning
Anaerobic sealants are pretty amazing things.
Lots of manufacturers, but not really common here other than industrial and fire sprinkler applications.0 -
dope
Hercules pro dope.this is my choice for years.0 -
teflon tape +
Teflon tape & Megaloc for us........0 -
pipe joint compound
we use rectorseal, permatex or blue block to name a few favorites0 -
Not a pro
But I used Hercules Megaloc on all of my gas piping and it worked well. I didn't use any tape as it seemed to be frowned upon. So far that is the only dope I've found that I really like.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Pipe sealant:
Teflon Tape on everything. Now, only the Blue Monster stuff in the 1/2" x 1429" rolls. You don't loose them as easily. Rectorseal #5 on gas or any of the other kinds that you can't get off your tools or clothes or Rectorseal #100 with Virgin Teflon or MegLoc on potable water. Almost 100% leak proof.
Heat is Teflon Tape with usually Rectorseal #5.
PROPERLY APPLIED Tape!!!!!0 -
Pipe dope
Rectorseal true blue. On copper male or female adapters i use blue monster teflon as well0 -
I'll ask again
Does anyone make 3/8" wide Teflon tape? I'd love to have it for the small stuff.0 -
teflon tape
I dont know about 3/8but they do make 1/4 in. I think markal makes it, its been a while since i had some. Now that you made me think about it i think i will order a few rolls.0 -
Markal 434-44081
thanks!0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
