Tool bags....
kcopp
Member Posts: 4,611
What do you guys use.... I am tired of the ones that you can lose a wrench or small tubing cutter in. Is there one that just has pockets w/o "storage" Makes them prone to be heavier than they need to be.
ty,kcopp
ty,kcopp
I am primarily a commercial tech
so most of my working life is spent in motor rooms and on rooftops with access via vertical ladders, so my bags have to be easily manipulated while climbing. My evaluation "jump" bag is a modified MOLLE ammo bag which carries two multipurpose meters, leads and temperature probes, a set of heavy duty jumpers, a six-in-one screwdriver, two wide jaw adjustable wrenches, a pair of wire stripper/cutters, a small selection of wire nuts, an LED flashlight and a small selection of spare batteries. This bag is backed up by a Klein Backpack tool bag for more extensive work, a construction tool belt with two twin pocket pouches for ladder, duct work and overhead hardware work and a 30" canvas and leather carpenter's bag which carries my sockets sets, wrenches and force tools (I usually pull out the hand truck when this bag comes out because it weighs a ton). I have a canvas bucket on the truck, but don't use it as much unless I have a helper or an apprentice with me and need to lift a great deal of material to a roof or down a hole.There was an error rendering this rich post.
Veto
I use a veto bag as well.There was an error rendering this rich post.
they look nice.....
but ouch...$$$$0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
