Help with thermostat
Andrew boiler
Member Posts: 44
The temp for the thermostat. Is saying its 72 and it is set at 68 is due to the room temp I thought when it's set at 68 it will stay at 68 can any one tell me what I am doing worn?
Too many posts..
Not enough information.
One post per subject."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
