Door drafter
Will a door drafter for under my door keep heat in my master bedroom?
  • Jack
    Jack Member Posts: 1,049
    Not sure what a "door drafter" is
    but, if you are having temp issues and the master needs a bit more ummph I would suggest you look at a Tjernlund Airshare. It is a transfer fan that has worked well.
  • Zman
    Zman Member Posts: 7,611
    Yes
    Yes they work great. It will fix your t-stat as well
    Albert Einstein
  • Andrew boiler
    Andrew boiler Member Posts: 44
    door draft dodger
    The door draft dodger works great thank you.
    Will it keep the heat in my bed room?
  • Andrew boiler
    Cold air
    I just got door draft dodger it still seems to be cold should I turn up the heat?
    Or how long will it take to use door draft dodger?
    Any ideas?
  • Eastman
    Eastman Member Posts: 927
    thank you
    that was the best
